  3. Licensing issues
Licensing issues
52 Posts 8 Posters 9.7k Views
    LeifHagen
    #21
    @tonigyllenberg you can contact me: [email protected] or +4797561599
      LeifHagen
      #22
        LeifHagen
        #23
        @Matti First one gives me something like this: MIIHBjCCBO6gAwIBAgIQD8dHLMPmUhKWlpzoDn25RDANBgkqhkiG9w0BAQsFADA1MQswC
          Hello all,
          As an update on this, investigations on the matter until now have shown that:
          • For some users the connection to cacerts.digicert.com is blocked.
          • Allowing outbound HTTP/80 to cacerts.digicert.com should fix the problem.
          • Connection can be tested by Windows PowerShell command:
            Test-NetConnection cacerts.digicert.com -Port 80
          We still do not have information on why the connection is all of a sudden blocked for many Norwegian customers. We are continuing to investigate with our certificate provider and will keep you informed as soon as we have more information to share. We apologize for the inconvenience.
          • fmohusF Offline
            fmohusF Offline
            fmohus
            wrote on last edited by fmohus
            #25
            Windows PowerShell command: Test-NetConnection cacerts.digicert.com -Port 80 returned TcpTestSucceeded : True. …But the problem remains unfortunately…
              @fmohus
              Because the Test-NetConnection succeeded,
              Try delete .solibri folder in your home directory and start Solibri again
              Try adding this line to “C:\Program Files\Solibri\SOLIBRI-26.4.1\Solibri.vmoptions”
              P fmohusF 2 Replies Last reply
                Patrick
                replied to Matti on last edited by Patrick
                #27
                @Matti Worked for me, once, then it suddenly stopped working again.
                  replied to Patrick on last edited by
                  #28
                  @Patrick said in Licensing issues:
                  Do you have two versions of Solibri installed? Are the both versions behaving the same way (not starting)?
                    Patrick
                    #29
                    @Matti Only one version. Also, works again now. 😅
                    • fmohusF Offline
                      fmohusF Offline
                      fmohus
                      replied to Matti on last edited by fmohus
                      #30
                      @Matti I tried the following:
                      (1) Deleted the folder c:/brukere/fm/.solibri (“brukere”=users in Norwegian Windows version)
                      (2) Tried to start Solibri - Browser says “You’re logged in” but Solibri still has the same problem
                      (3) Added -Djavax.net.ssl.trustStoreType=WINDOWS-ROOT to folder C:\Program Files\Solibri\SOLIBRI\Solibri.vmoptions (REMARK: The folder name by me is just “SOLIBRI”, not “SOLIBRI-26.4.1”, does this matter??
                      (4) Started Solibri again - same problem
                      (5) Did BOTH point (1) and (3) again, and then started Solibri - still same problem.
                      Screenshots:
                      abe319e2-bd6e-4067-8e98-50feb7877e96-image.png 5d51e809-1e2d-4e96-9c0a-fc405eae705e-image.png 2c7e6627-d6e6-4677-b33e-8637a6482d2a-image.png
                      • fmohusF Offline
                        fmohusF Offline
                        fmohus
                        Solibri Office works again at login this morning.
                          replied to fmohus on last edited by
                          #32
                          @fmohus said in Licensing issues:
                          @fmohus, thanks for sharing. How about @Patrick @SigneLaksaa @LeifHagen ?
                          fmohusF 1 Reply Last reply
                          • fmohusF Offline
                            fmohusF Offline
                            fmohus
                            #33
                            @Matti Do you have a few words about what fixed it? Something to do with certificate provider in Norway?
                              LeifHagen
                              We still have the same issues
                              • SigneLaksaaS Offline
                                SigneLaksaa
                                Problem today as well…
                                • fmohusF Offline
                                  fmohusF Offline
                                  fmohus
                                  UPDATE: Still seems unstable, the next login failed here as well.
                                    You can try following workaround:
                                    Solibri installation has a certificate store file. I imported the Digicert certificate into that.
                                    1. Take a backup of this file “C:\Program Files\Solibri\SOLIBRI-26.4.1\jre\lib\security\cacerts”
                                    2. Replace the file with the one that is inside the attached zip
                                    3. Start Solibri
                                      cacerts.zip
                                      LeifHagen
                                      #38
                                      @Matti said in Licensing issues:
                                      3. Start Solibri
                                        cacerts.zip
                                      Tested now, still no license
                                        Hello all!
                                        As an update on the situation: Based on the current understanding, the issue seems to be related to Akamai datacenter. This explains why the situation is limited to Norway.
                                        For the time being, in order to regain access to Solibri, have your network or system administrator add a static A record on your corporate internal DNS server:
                                        Hostname: cacerts.digicert.com
                                        IP Address: 23.218.216.34
                                          LeifHagen
                                          Please inform us when there is a permanent fix for this issue as we wish to roll back the static IP when possible
