  3. Startup Issue : java.security.cert.X509 error
34 Posts 11 Posters 14.6k Views
    @celineman did you try that option?
    • C Offline
      C Offline
      celineman
      wrote on last edited by celineman
      #10
      Is it just simply adding that line to Solibri.vmoptions? and then run Solibri?
      I did that but doesn’t work… @Matti-Kannala
      • K Offline
        K Offline
        keithwilkinson
        #11
        @Matti-Kannala said in Startup Isse : java.security.cert.X509 error:
        -Djavax.net.ssl.trustStoreType=WINDOWS-ROOT
        Hi, tried adding that here but no joy. I’m also UK-based and using Windows.
          wrote on last edited by Matti
          #12
          Just to check if you are having some firewall or similar that could affect:
          1. Open https://api.solibri.com/ to you browser (Chrome)
          2. Click the icon in front of the address bar
          3. Click “Connection is Secure”
          4. Click “Certifcate is valid” (In Edge browser there is a Certificate icon instead)
          5. Check that certifcate matches: Cloudflare, Inc. and public key 80d1db0dd47ad24ac24c05fe19273a1a4b39977563a3f9a69ae970b53a1b44fa
          K 1 Reply Last reply
          • C Offline
            C Offline
            celineman
            #13
            This is what I got @Matti-Kannala
            • K Offline
              K Offline
              keithwilkinson
              #14
              @Matti-Kannala
              That all seems to match here.
                replied to keithwilkinson on last edited by
                #15
                @keithwilkinson said in Startup Isse : java.security.cert.X509 error:
                Was this from a PC where the Solibri is not starting?
                • K Offline
                  K Offline
                  keithwilkinson
                  #16
                  @Matti-Kannala Yes, this is the machine were Solibri isn’t starting.
                    replied to celineman on last edited by Matti
                    #17
                    @celineman said in Startup Isse : java.security.cert.X509 error:
                    This is what I got
                    In that page:
                    1. Click the Details:
                    2. Click Export… and save the cert to local disk
                    3. Click Windows key
                    4. Type “CMD”
                    5. Right Click the Command Prompt icon appearing
                    6. Click “Run as Administrator”
                    7. Run command
                      “C:\Program Files\Solibri\SOLIBRI\jre\bin\keytool.exe” -import -noprompt -cacerts -alias api.solibri.com -file “<path to the file exported file>”
                    8. Type “changeit”
                    • C Offline
                      C Offline
                      celineman
                      I don’t know why I can’t type in “changeit” @Matti-Kannala
                      • K Offline
                        K Offline
                        keithwilkinson
                        #19
                        @Matti-Kannala Tried this along with a couple of other suggestions from tech support but still the same issue.
                        • K Offline
                          K Offline
                          keithwilkinson
                          any other ideas on this?
                          • EricE Offline
                            EricE Offline
                            Eric
                            @celineman @keithwilkinson Are you still facing this issue?
                            We received information that other users don’t face the problem anymore.
                            could you please confirm you can log in and successfully launch and use Solibri?
                            Thanks in advance!
                            • C Offline
                              C Offline
                              celineman
                              I can launch Solibri Office now
                              • K Offline
                                K Offline
                                keithwilkinson
                                Same here - mysteriously working again. Any indication as to the cause?
                                • EricE Offline
                                  EricE Offline
                                  Eric
                                  wrote on last edited by Eric
                                  #24
                                  @celineman @keithwilkinson Glad to hear all is fine now!
                                  We’re still investigating and so far the issue seems to point towards Cloudflare since this issue disappeared after they did a maintenance break earlier today, only for the UK.
                                  Despite this, we apologise for the inconvenience.
                                  • K Offline
                                    K Offline
                                    keithwilkinson
                                    no worries, that would make sense. Thanks for the update.
                                    • EricE Eric marked this topic as a question on
                                    • EricE Eric has marked this topic as solved on
                                    • C Offline
                                      C Offline
                                      celineman
                                      #26
                                      Hi, I have this startup problem again today. @Matti-Kannala
                                        Thanks for reporting. We are looking on this. I have not seen other reports yet.
                                          Mark-Felix
                                          Hi, I have this startup problem as well. @Matti-Kannala
                                          Firewall ports and Proxy settings are in accordance to Firewall-Settings. I recognized that Settings / General / User is empty. Any suggestion?
